Breath 26" Bike
Amas
I dont see the point in copying koxx, for that reason i dont like it.
Seriously? It's probably got something to do with them looking absolutely divine, being hugely popular, and considered about the most upmarket frame currently on the trials market.
If they can make an almost exact replica and sell it on cheaper than the Koxx, they're bound to make a metric f**kton of money.
Sure it's unoriginal, but since when is profit about originality?
Have you not wondered how, since Koxx went super high BB, almost every other company has done the same? Koxx are like a hyper-brand in a clothing company. They dictate the fashions/trends of the time because they're the most sought after frames.
  • Like 1
Yes i do understand that but i would prefer to see a different styled frame as appose to a mirror image one. I hate how other company's copy koxx, if everyone copys then frames will all ride the same because they have a similar geo' I do understand your point about the clothing example and profits etc, but i just dont like the fact that everyone copys, every frame should be different, unlike this one.
Looks lush, and undeniably the weight is amazing.
But the quality of the frames just look shocking, seen so many of these frames with that very finish and they just crack or snap, or bend (cough liam N cough). But I suppose that's what you sacrifice when you get a cheap/light frame.
  • Like 1
I need to say that this frame is little bit hevier than Sky2..
nice bike (Y)
This Frame 1730g include headset
Where did you get those titanium magura parts (barbed fittings, shroud nut, ...) ?
The Ti fitting brand name is call Ellen
And Ellen have the hope Ti Lever Pivot Bolt and Nut
it very nice but i haven't disc brake :(
i feel breath frame is very strong
Here is about Breath rider video
http://www.tribalzine.com/?Zhao-Xuan-a-Chinese-rider-with
What are those pedals' spindles you're using?
Echo spindle with try-all body? How does it work? I thought it couldn't work together...
Tryall Superlight Caged 2010 with Ellen Rainbow Titanium axle and bolts
Here is my bike config:
- Frame: Breath 26"
- Forks: Tryall Carbon
- Front hub: ZHI Non Disc 32h with Ellen Rainbow Titanium axle bolts
- Rear hub: ZHI 32h 116mm Non Dise with Ellen Rainbow Titanium axle bolts
- Front rim: Neon 32h 3.5 26" silver.
- Rear rim: Rockman 32h 4.7 26”, silver
- Spokes: DT Double Butted
- Spoke Nipples: DT
- Rim tape: Custom made
- Inner tube (Front): Bontrager 2.125x26"
- Inner tube (Rear): Bontrager 2.5x26"
- Front tyre: Tryall Shift 26"
- Rear tyre: Tryall Stiky Lite 26"
- Front brake: Magura Orange HS33 with 4 lever
- Rear brake: Magura Orange HS33 with 4 lever
- Brake pads (Front): TNN Belaey
- Brake pads (Rear):TNN LGM
- Brake clamps: Echo SL with Ellen Rainbow Titanium bolts
- Barbed Fitting:Ellen Rainbow Titanium
- Shroud Nut:Ellen Rainbow Titanium
- Cranks: Breath ISIS 170mm, Silver
- Freewheel: Echo Titanium 108.9 18T
- Chain: KMC Z610HX
- Rear Sprocket: Ellen Titanium 15T
- Pedals: Tryall Superlight Caged 2010 with Ellen Rainbow Titanium axle and bolts
- Bottom bracket: Born Titanium with Ellen Rainbow Titanium bolts
- Bashring: Tryall Halfring
- Headset: Breath internal
- Stem: Born 127mm 30° with TRY-ALL Titanium bolts
- Grips: French
- Handlebars: Tryall Carbon Riser 2011
Breath and Bionic/zhi are completely different companies for one...secondly when you build a frame to such a low price point then try and compete with Koxx's weight im afraid somethings got to give, the slightly earlier zhi's that were around 1.6-1.8kgs were a lot stronger.
