What Makes A Manual Machine?
eskimo
I'm looking into another frame already as i can't seem to find a decent bike to manual. I like my normal trials moves and won't be giving that geo away for a 24" style bike though.
I haven't found a bike as good as the Toxsin One yet and due to the small amount of them about i really don't think i'm going to get a hold of one again. I've tried numerous stems and a few frames but nothing that actually likes to hop in and out of manuals without using the pedals.
I can manual most bikes well but my Bionic, A1 Long & Holroyd don't really cut it.
Input anybody?
I was thinking of a Echo Hifi, yeah maybe the last frame to choose for this but the short go i did have on one i was impressed. Well not impressed, but suprised by that short rear end.
I think for most people Riser bars are a must an depends on your height aswell, if your vetically challenged like myself something very short like an older revell etc (for sale (Y)) would be better but some of the guys on longer bikes if can get enough leverage to pull up you could manual a longer bike.
The thing being i don't have a problem with the initial manual and balance. I just want something that can jump out of and jump into manuals without having to dislocate my shoulders.
The Bionic is 380mm on the chain stays and it really likes to take it's time to get into balance. My A1 was shorter on the rear end yet was longer overall, which helped alot. I might measure up the A1 and being a mod-stock slam the wheel which should create a shorter back end even more.
So what is the geo on the Pure 04 then? That's the one Rowan used to ride isn't it? They also have a seat post :shifty:
thats what i used to ride too... The wheel base on mine was 1065 with pash forks and 10mm BB rise, i think the rear end was about 375 but I can't remember :S
Theyre actually the nicest frames ever! they hop so well and you can hop to manual without any problem!
Edit: I used to use upright Monty bars so it felt more like my BMX B)
Edited by samdoman
bionic has a bb of 30 i think so that won't help. you want something 10/20 and 380/385 chainstays. It should still be nice then for everything. The reach will affect though how long a bike feels so a long reach can make a short bike feel longer and it then makes the fornt end hard to pull up.
bar and stem set up makes a big difference.
Edited by basher
What about the toxsin 2?
If you cant manual your Bionic or Holyrod, then your technique is at fault or isnt dialled. Adamant A1/long is harder to master unless you use riser bars and stem with 20 degree rise (length 120-130mm). if you cant tuck your butt low over the backwheel, then try having your lead foot positioned at 12oclock and your back foot at 6oclock. your back foot position is your main counterbalance before other techniques come into play (ie; feathering back brakes, hips, knees, and leg pumps). just generally make more practice.
No, no and no :P
It's just not much different from other frames that i rode.
I can, i just
:P you didn't read the whole thread did you.
Sounds purely like a setup issue, more than a frame? Or technique, I guess. I hardly use my shoulders when I'm hopping into or out of manuals, it's all leg/lower body for me?
But to counter that, I could manual my T-Master proto OK, and could bunnyhop it OK and hop 3 it, but I could do that on my T-Pro too. It's just a case of tweaking your setup really, or maybe just altering some of the components to make it easier. I'd point at the bar and stem...
