Rockman Kortz Full Build!
Bigman
Hey Guys,
Here is my new Rockman Kortz, Recived it yesterday and got right on ahead with building, and then after sorting my front brake went out for a quick ride, First impressions are that it is very good on the back wheel, the high BB helps alot, and even with the high BB it taps as well as the ISIS did, which was surprising, Sidehops very nicely too. Hopefully will give it a proper ride tomorow in plymouth.
Spec:
Rockman Kortz Frame
Pashley 4 bolt forks
Try-all cranks with atomz bash and 18t trialtech sprocket
Cane creek S3 headset
Front hope mono lightweight with custom singlewall and square holed DX32
Rear CK classic HD with custom square holed trialtech rim
Front try-all tyre
rear Continental Rain king Tyre + ultralight innertube
HS33 front and rear, 4 finger lever blades, rock blues and custom drilled 4 bolt mounts
Tartybikes forged stem
Proto Rockbars
Trialtech foam grips.
There will be a few changes happening soon when i should be recieving some more new products from Rockman!
Big Thanks to Rockman for supplying me with the Frame and other components!
Let me know what you guys think!
EDIT: new pictures with silver bars and matching levers.
Adam
HOT TO TRY :P !!
really like these, would love a mod virsion, but if it only came out in disc would be urber gay, the rockman 20" thats out now is really nice but only in disc :/
hope to see a few clips of you on the stuff you made too :). looks really well and your setup's beast!
